Tool palette features
The standard tool palettes (Basic and Tool Sets) and any custom tool palettes have special features that other palettes do not. Tool palettes and their tool sets can be created and customized using the Workspace Editor (see Personalización de los espacios de trabajo).
Pop-out tools
On tool palettes and sets, an arrow on the right side of a tool icon or label indicates additional, related pop-out tools. Click and hold the mouse to open the list of pop-out tools.
Utility menus
Each tool palette has a Utility menu on the title bar that controls the palette and tool display.
Menu / Command
Action
View Tools As
Icons/Icons and Text/Text
Select whether to display only an icon, both an icon and a text label, or only a text label for each tool
Sort Tools By
Manual Placement/Ascending Alphabetical/Descending Alphabetical
Select whether to display tools in the order appearing in the Workspace Editor, or in either ascending or descending alphabetical order according to text labels
View Tool Sets As
(These options are available only for tool palettes with multiple tool sets)
Select whether to display only an icon, both an icon and a text label, or only a text label for each tool set in the palette
Sort Tool Sets By
Select whether to display tool sets in the order appearing in the Workspace Editor, or in either ascending or descending alphabetical order according to text labels
Place Tool Sets At
Top/Bottom of Palette
Select whether to display tool set selection buttons at the top or bottom of the tool palette
Customize
Opens the Workspace Editor Options dialog box (see Personalización de los espacios de trabajo for details)
Tool set selection buttons and tear-off palettes
If a tool palette has multiple tool sets (as does the Tool Sets palette), selection buttons for each tool set display on the palette. To display a tool set’s tools, click the appropriate button. The button is highlighted to indicate which tool set is active.
To see multiple tool sets at once, drag a tool set’s selection button off the main palette. This creates a separate, temporary palette for the tool set, with a “perforated” top edge. Like other palettes, these tear-off palettes can be docked, resized, and minimized. To close a tear-off palette, click its close button.
Palette display options
Acoplamiento de paletas
Saving palette positions and settings
Ventana de aplicación
